tachometer for XJ6
CaptRandy
Can anyone tell me if the small round rivets on the outside of the tach housing serve any purpose? I am instaling one in my Healey BT7 and they stop the tach from fully inserting into the dash. If they are non functional I will grind off and then insert. The reason I wonder about them is that the tach works magnetically and I know on compasses there are small objects on the compass that work in conjunction with the compass to offset variation and deviation.
B tachometer cable has a hole in it Restoration & Tools 7
F TR6 Tachometer lighting Triumph 8
S Engine or Tachometer Odd Problem Austin Healey 7
M Tachometer not working following ignition upgrade Austin Healey 10
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
E Oil leaking from the Tachometer cable Austin Healey 5
E MGB Tachometer 65 mgb MG 5
vette Just a note to Bill Young about his work with the electronic tachometer. Austin Healey 2
RAC68 Calibrate Smiths Tachometer Austin Healey 12
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
T TR2/3/3A Noisy tachometer Triumph 9
S Intermittent operation of tachometer Austin Healey 9
Lin Tachometer/Dwell Meter Austin Healey 10
N Tachometer?? Spridgets 6
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
W Tachometer reads high when engine compartment heats up Austin Healey 3
D TR2/3/3A curious tachometer take-off Triumph 5
NutmegCT T-Series Tachometer repair MG 15
Boink Tachometer seize? Spridgets 11
Michael Oritt Electric tachometer connections--No Healey content Austin Healey 7
M TR2/3/3A Tachometer Malfunction Triumph 7
drooartz Geeking out over a tachometer Spridgets 15
S TR4/4A Tachometer Triumph 5
GTP1960 TR2/3/3A Tachometer vs rpm analyzer? Triumph 5
Roger Lotus Elan S3 - Rev Counter [Tachometer] needed Lotus 4
5 Lazy Tachometer Spridgets 14
P I need a non-working electric tachometer for parts Spridgets 0
DanLewis Electronic tachometer for Bugeye Spridgets 18
J Mechanical tachometer to electric Austin Healey 11
J WTB: Bugeye Tachometer Blanking Plate Spridgets 11
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
T BJ8 Tachometer and Fuel gauge stopped working. Austin Healey 27
Marvin Gruber Tachometer reading too high Jaguar 4
A Need Help with a Tachometer -- the drive portion. Austin Healey 1
M Quick tachometer wiring question on a '65 Spridgets 10
D Tachometer Triumph 9
L BJ8 Tachometer problem Austin Healey 6
P Tachometer versus lights Austin Healey 5
apbos Tachometer ID Smith's Rn1412/00 Spridgets 5
pkmh BJ8 Tachometer, "sparking" Austin Healey 35
G T-Series Tachometer and ignition switch MG 16
I Reproduction tachometer drive quality? Spridgets 4
K TR2/3/3A TR3 Dist Pedastal Tachometer Attachment? Triumph 3
K tachometer question Spridgets 9
B MGB MGB tachometer erratic, engine cutting out.... MG 11
F Ignition System/Electric Tachometer Triumph 9
F Spitfire Spitfire Electric Tachometer Problems Triumph 5
