goloch
Having finished my work on the ignition system, my attention is now focused on the carbs as I try very hard to get my 71B through emissions inspection. The next obvious step to me is tuning the SU carbs. Is there anything else to check (already did valve clearances twice) before going to the carbs? And while I'm working on the carbs is it worth it go ahead and rebuild them? What are the chances of screwing something up irrevocably (aka needing to pay someone else to fix it) if I start mucking around with needles, jets, etc?
Also, my car seemingly has the wrong model of carbs for its year. From everything I've seen, SU HS-4 carbs should be on a 71. I have no separate float chamber which implies HIF-4. Is there any chance the HIF-4's are original to a 71? The engine is missing its ID plate so I have no idea if the engine is even original. I'm guessing the answer lies in the model number of the carbs (AUDxxx); where do I find that?
As an aside the (cracked) distributor is from a 65 based on the Lucas part number stamped on it. I'm not even sure if it's actually compatible with the (now-reinstalled) manifold advance. What a mess...
