I like the saying that "what's wrong with your SUs is your ignition." But I've got that cool new Pertronix on there and a new coil, to boot.
It only misses once, maybe twice, and only if I really jump on the gas. The miss is in each of 2nd and 3rd at between 2800 and 3500 RPMs. Sure doesn't seem very material, but it's bugging me.
I assume it's most likely fuel related? I'll check and clean the floats and needles. What about the mixture and dashpot oil? I'm opened at about 8 flats on each carb. The trick about raising the piston 1/32nd until the engine accelerates and then slows down, doesn't seem to work on my leading carb. It just seems to accelerate, and that was case even after closing all the way down to 4 flats and that makes no sense to me.
Any ideas or advice here?
