'73 tr6, US Spec.. WR wire came of tang on starter (has happened a few times over 20 years...I've tightened and pushed back on). This time, i noticed a second wire, WY, was broken off. Can't find where it was ever attached to the WR one... At any rate, I stripped the WY one and stuffed inside the clip and pushed it back on the tang like I always have, and not the car fires and immediately dies. Since i couldn't see where it used to be attached, and my wiring diagram doesn't show a WY wire at the solenoid, I put it on the big red lead on the solenoid and just put the WR one on the tang. Naturally, the car started right up and kept running. I immediately knew that wasn't wired right since as soon as i sat in the car to start it, the red light was on in the gauge telling me the system was already hot. Needless to say, I had to pull the coil wire to shut it off. So... then I found this forum and saw a note saying some cars had the WY, but it wasn't necessary and could stay unattached. I left it unattached and all I got with the WR back in place was a click from the solenoid.
So what's wrong???????
dave
dave
