sputtering redux
nevets
Just a follow up on my previous post. As before, the car runs smooth and strong under acceleration but sputters/misses at a constant RPM, as when cruising in 3rd or 4th.
Things I’ve done: New points, plugs, condenser, rotor, and coil. Adjusted timing with timing light and it appears to be ok. Difficult to determine if it’s ignition related or carburetor related. Pulled a few plugs to judge whether it’s running rich or lean but after only 20 miles of driving, plugs are too new to tell a story. They are definitely not sooty or oily.
Watched the engine idle in a very dark garage and saw no arcing around dist cap or plug wires.
One thing I noticed is that the fabric insulation is frayed on the thin black wire inside the dist, not the ground wire, the other one. Sorry for being so vague in my terminology. And there is no felt oil plug in the top shaft, which there should be, according to NN’s tech briefs. My next step is to replace this wire and attempt to lightly lube the dist per the manual. Perhaps replace all the HT wires as well.
If the car is running too lean as someone suggested, could I test this theory by simply driving the car with the choke out slightly?
Any additional thoughts would be appreciated, thanks
That's a trick I use on my motorcycle. If the engine runs better with the choke, it is lean.
Thanks Greg. I was holding off responding, hoping there would be a few more comments or suggestions. I guess this issue is either one that no one else has experienced or there are just too many variables to make a diagnosis. I will plod through all the easy stuff and report back on my progress. I'm still thinking ignition.
A quick update...I checked the point gap and it was too wide. After adjusting the points, the car is running noticeably smoother.
tr6web TR6 Sputtering help Triumph 6
F TR6 Sputtering at low rpm Triumph 16
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
F TR6 Sputtering along Triumph 14
bugedd Sputtering Spridgets 15
PeterK TR4/4A Stalled project, now sputtering Triumph 3
S BJ8 Sputtering at High Engine Speed and in Overdrive Austin Healey 36
J MGB 69 MGB sputtering problem MG 5
nevets sputtering issue fixed...it was the timing Austin Healey 4
Bremer TR2/3/3A TR3A sputtering after 1 hour of driving Triumph 1
drooartz Sputtering in left hand turns Spridgets 17
nevets intermittant sputtering follow-up Austin Healey 13
nevets Intermittent sputtering Austin Healey 38
K TR2/3/3A TR3A: Occasional sputtering and hesitation? Triumph 4
K TR2/3/3A TR3 Coil + Heat = Misfiring and Sputtering? Triumph 6
TR4A_IRS Sput...Sput...Sputtering? Triumph 19
Shane Fully choked and sputtering Austin Healey 3
Mio Sputtering under load Spridgets 27
U sputtering at start Spridgets 3
Wana UPDATE: Engine Sputtering Austin Healey 2
Don Elliott TR4/4A Sputtering when hot TR3 & TR4 Triumph 29
Luke_Healey Ignition/Sputtering troubleshooting? Spridgets 16
Wana Engine sputtering... Austin Healey 22
H Rough Idle and Sputtering Austin Healey 22
mabbott TR6 73 TR6 Sputtering problem? Triumph 17
wkilleffer Sputtering/backfiring around left-hand turns MG 4
Gray_Cat Sputtering/warmish Running BN1 Austin Healey 2
K ran fine, now sputtering/backfiring at speed MG 8
T TR6 TR6 Sputtering Triumph 12
W ZDDP REDUX Austin Healey 10
Bob_Spidell 'Barn Find' 100M Redux Austin Healey 0
J Urethane redux and a question about stub axels Triumph 3
mgb4tim T-Series Wind Blocker Scratch and Dent Offer - redux MG 2
M Oil filter Adapter Redux Spridgets 10
StupidHippie Cup holder redux Triumph 22
C Fan Color, Redux Austin Healey 7
MadRiver Alternator redux Triumph 14
DrEntropy Windshield Wars Redux... MG 2
C Fuel Pump Redux Austin Healey 3
MadRiver TR5/TR250 TR-250 Seatbelt Questions Redux Triumph 4
G TR2/3/3A "FREE TR3" - Redux Triumph 7
philman what to bring on a road trip .... redux Other Cars 0
G Oil Pressure Too Low - Redux.... Triumph 2
S TR6 Creaking TR6 Redux Triumph 2
R Fuel Problem redux Austin Healey 31
