Re: spitfire transmission and j type O/D oil quest
TR3driver said:
Bugeye58 said:
GL-4 is supposed to be bronze friendly, unlike GL-5.
Conventional GL-4 has the same additive as GL-5 (that corrodes yellow metal); it just has less of it. It's that additive that gives old gear oil that distinctive smell.
That distinctive smell is the sulfur. Unfortunately this information is also about 10 years out of date.
GL-5 has a slightly higher concentration of sulfur in it. In early oils, the sulfur was just that, plain sulfur. In MODERN / Good quality oils, the sulfur is part of a compound. What happened in the early GL-5 lubes is that as they absorbed moisture, under heat, the sulfur would form H2S04 - Sulfuric acid - that is what damages the yellow bits. This also happened with GL-4 oil however, since there was a lower concentration of sulfur, the eventual concentration of H2SO4 remained lower and they did LESS damage to the yellow metal bits.
MODERN / Good quality oils are a different story. There is Sulfur, but it is already part of a compound, and is NOT free (chemically) to combine with moisture in the oil -> therefore, no sulfuric acid.
There is also (usually) a difference between GL4 and GL5 in the "slipperinesses" GL-5 is more slippery. This is VERY good in the differential. In the transmission, it is not so good since it affects (negatively) the effectiveness of the syncro operation. Specifically designed Manual transmission fluids overcome this problems.
The problem mentioned by several posters with using synthetic gear oils is NOT the oil itself. It is will the additive pack, which doesn't provide enough "grab" for the syncros.
Using 30w oil in the trans also has its own problem mostly in that it will increase the wear on the gear set since it is NOT designed for that pressure / usage.
However for the syncro, the best bet probably would be the Red Line MTL which is a 70W80 fluid
Note that the viscosity #s are NOT the same for gear oil and motor oil an 80 gear oil has a very similar viscosity to a 30 motor oil.
https://www.bobistheoilguy.com/visc.html
Now as for the DIFFERENTIAL use a good quality GL-5 since it is slipperier which will reduce wear on the expensive bits (the gear!)
Finally, a large part of the reason that the old oils ate up the yellow metal is that people just don't bother changing the gear oil! if they had done so, even the older formulations would never have formed sulfuric acid and there would not have been any damaged gearboxes! even with modern oils, changing the oil is a good thing. Oil is MUCH cheaper than a rebuild.
