speedometer cable right angle adaptor
gubba
Hi fellas...anyone no where you can get a right angle adaptor for the HVDA tranny conversion. I keep loosing cables on long trips. TIA
This is the one area that I had a real problem with Herman's support. I too had speedo cable problems and ended up fabricating my own right angle adapter using a mgb right angle drive and parts from the Toyota speedo cable and a Triumph speedo cable from the adapter to the speedo.
I had the same problem and called Herman about a month ago. He not only knew about the problem, but sent me a picture and part number for the angle adapter. It is off a Cressida, ordered it online to find the lowest price and it works perfectly.
Call Herman.
Murray
Thanks fellas...I did email Herman and he sent me that info this morning...so off I go..
