Is it normal for there to be some amount of bounce in a Jaeger speedometer needle that coincides with the ratcheting of the two brass odometer gears? During repair I did a benchtop confirmation with the odometers NOT installed, using a DC motor and controller set to the calibration value printed on the face. It was perfect 60 mph with no bounce. I then installed both odometers for reconfirmation, but now the speedometer bounces about 1 mph every time one of the odometer brass gears is ratcheted. I tried two different cables and also direct drive without a cable, but the result is the same. Any ideas?
Joel
1959 TR3A TS57134
Joel
1959 TR3A TS57134
