swift6
A little background first... In Fort Collins, they no longer salt the roads in the winter. They use a chemical spray that is some sort of synthetic urea. When all the snow goes away this stuff sticks around and makes the roads a little slippery (it's also a bugger to wash off) when the morning dew/frost appears.
Now on to the fun. /ubbthreads/images/graemlins/devilgrin.gif
This morning as I was leaving town (my TR8 is my daily driver, not great in the white stuff but that stuff doesn't actually stick around for very long in Fort Collins.) I caught the tail end of a left turn direction arrow through an intersection. Note I was not starting from a dead stop but had a good bit of speed up, nothing illegal though. As I approached the turn I downshifted and accelerated through the corner, as you do, when I felt the distinct sensation of my rear tires losing grip under power. Then the front started to go. Nothing drastic mind you, just a bit of slipping. As the roads were nearly empty, a rarity in itself in Fort Collins, I decided it was time to play. /ubbthreads/images/graemlins/jester.gif
So I fed in a little more throttle and dialed in some opposite lock and presto. Four wheel power slide that was quite easily modulated by throttle and steering inputs. What a blast! /ubbthreads/images/graemlins/driving.gif
My TR8 can be coaxed into doing the same thing on normal dry roads but it takes a bit more effort. /ubbthreads/images/graemlins/wink.gif This morning was just the right thing to do to start the day off with a smile. Just thought I would share the experience with you lot.
