Spent some time last night trying to set the static timing on the Tunebug. I used the Haynes manual as my reference, and keep in mind that I've never done this before. Took a while to find the timing mark, but I think I found it.
Once I figured I had it set, I cracked open the factory manual and saw that it says to remove the vacuum line from the distributor before setting the timing. I didn't know to do this. Do I need to go back and reset the timing now, with the vacuum line off?
This is on a stock 948 motor, BTW.
Also, any other hints for setting the timing? I'm not really sure how to know when it is right.
