Sanding blocks
Britishautobody
Thought I would post a thought or two on sanding blocks guys might want to consider for sanding/ blocking. When I first begun in the trade I used to have a aluminum long sanding board,used to get things very straight. Then I found myself going towards the hard plastic yellow board. What I didn't realize is over the years it was warping and not true- flat. My bodywork/primer blocking was getting harder to get straight and I could not figure out why. A friend told me my board was warped, he was right,put it on a level surface and sure enough.
So moral of the story is a I went back to a aluminum/wood reinforced long board and It feels like the magic is back once again. If you need flat get a sanding block that wont flex.
Yep, I've also got a wood/aluminum one of the shelf - best there is to use...& I prefer the hand one to my air board.
Bayless Ready for final block sanding Spridgets 5
S TR2/3/3A wet sanding and amonut of paint Triumph 13
K TR2/3/3A Scuff sanding a car to prep for a paint respray? Triumph 9
tomshobby color sanding done and first stage buffing Spridgets 4
D Block sanding vs. "freehand" Spridgets 17
H Sanding the paint, like rings on a tree Austin Healey 8
HealeyPassion Sanding and buffing new paint...Latest Austin Healey 8
bighealeysource sanding and buffing of paint job Restoration & Tools 12
J Ready for sanding Spridgets 1
bash Sanding discs for air sander? Restoration & Tools 2
JPSmit Sanding epoxy primer Restoration & Tools 5
I TR6 Veneer sanding, TR6 dash Triumph 3
KLUTZ T-Series Stripping, Scraping, Sanding, Etching... MG 1
7 Wet Sanding Austin Healey 22
JPSmit I Love Power washers but - sanding question Spridgets 9
F For Sale Rover V8 blocks for sale Other British Classifieds 1
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
G BJ8 Spare Wheel 'Blocks' Austin Healey 3
C HD6 Carburetor Spacer Blocks Austin Healey 4
5 TR2/3/3A Wooden blocks Triumph 3
5 Hardtop wood blocks Austin Healey 3
T TR2/3/3A TR3A tight steering/silent blocks Triumph 8
C TR2/3/3A 1957 TR3 Garage/ barn find> On blocks 48 years Triumph 42
deadair TR2/3/3A For those who's TR3s are up on blocks Triumph 14
Brosky Sealing blocks are available again Triumph 5
BOBBYR Sleeved blocks Austin Healey 11
Lin 2" spacer blocks for front suspension Austin Healey 6
Mg_Bizzle Lowering blocks and front sus [newbie fitting q's] MG 20
Darwin Up on blocks Triumph 2
G She's up on blocks....again Triumph 3
T Cracks in Alpine blocks Sunbeam (Rootes) 3
