TR4/4A Reversing upper fulcrum link
spbvmb
Member
I have a late (1964) TR4 which has the upper fulcrum link installed with the curve away from the shock bolt and rubber bushing. The vertical link has a 3 degree caster and the upper wishbones are asymmetrical. It seems to be the general opinion that this upper fulcrum link is mounted backwards for this arrangement. When I reverse the fulcrum link it crowds the shock bolt to the extent that the rubber bushing will not fit over the bolt. Reversing this upper fulcrum also increases the positive camber which I am not sure is a good thing. I await your collective wisdom on how I should proceed.
Thanks for your ideas
Phil Brooks
Ah, good. Now you can test my theory that the fulcrum pin didn't get reversed until the TR4A. Park the car on a reasonably level hard surface, then hold a carpenter's square up to each front wheel in turn, with one leg resting on the ground and the other leg vertical at the wheel centerline. Measure from the carpenter's square to the edge of the wheel at the top and bottom. With a bit of math, that will tell you how close you are to the specified camber. Each 1/4 of difference is (roughly) 1 degree of camber.
Obviously, my theory is that your car is already correct and Mr. Williams is wrong.
Randall,
Thanks for your response. I have already calculated the camber using a level with blocks attached to touch only the wheel edges top and bottom. The camber is positive 3 degrees or 3/4" in 15" which agrees with your 1 degree per 1/4". The spec is 2 degrees positive camber. I also made a jig with 2 pegs over which I placed the fulcrum and wishbone assembly and marked the ends of the wishbones. Reversing the fulcrum (curve toward shock bolt) adds 1/8" to assembly length and to positive camber. The outboard upper and lower wishbone vertical pivot spacing is about 10-1/4" which should add more than 1 degree to positive camber. The fact that with the fulcrum installed with outboard curve, the shock bolt can no longer be centered in the tower hole, is also of concern.
Phil
Phil
Thanks for the info, Phil. Proof enough for me!
nevets Reversing With Overdrive "On" Austin Healey 8
6 Reversing Camera Other Cars 1
T Reversing w/. OD engaged - symptoms? Triumph 14
jjbunn Reversing Light Brackets Jaguar 7
G Reversing light problem - need a bit of help Triumph 22
19_again reversing polarity on generator MG 1
D TR2/3/3A Question about bushing on the upper suspension.... Triumph 13
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Rut MGB 62-67 upper MGB steering shaft MG 3
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
P MG TD Bonnet Upper Sections MG Classifieds 0
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
R TR2/3/3A Upper Wishbone Bushings Triumph 12
L TR2/3/3A Upper steering column bushing Triumph 8
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
D 62 tri-carb upper fulcrum pins Austin Healey 4
J TR4/4A Upper steering flex coupler Triumph 4
R TR6 Body Parts Source, Upper Midwest Triumph 6
S TR2/3/3A lube for upper A bushings Triumph 2
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
mt10flyer TR2/3/3A poly bushings - upper wishbone Triumph 2
J TR4/4A confirm upper wishbone arms Triumph 11
KVH General TR Upper Control Arm Reversed? Triumph 5
Joe Reed MGB Another easy fix....upper radiator bracket MG 5
vickxxx TR2/3/3A Upper cylinder oiler Triumph 8
B TR2/3/3A Upper Control Arm - which overlaps which? Triumph 2
GTP1960 TR2/3/3A Tire condition, upper side wall splits...dangerous? Triumph 12
D Re-fitting vinyl on center upper console bj8 Austin Healey 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
Morris OOS Upper Link Spridgets 6
TRclassic3 TR2/3/3A SU Upper jet bearing position Triumph 5
T TR4/4A Upper steering column Triumph 3
G TR2/3/3A Steering Box Upper Bearing Race Triumph 1
C Sway bar upper installation help please Austin Healey 3
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
B TR2/3/3A Adjustable Upper Fulcrum for TR3 Triumph 9
V Upper Ball Joints Triumph 16
B Upper radiator stay rods black or body color? Triumph 11
bcbennett '74 upper radiator hose Triumph 5
T TR2/3/3A TR3A upper windshield seal Triumph 12
I TR6 TR6 upper A post seals Triumph 0
T TR2/3/3A TR3 upper A arm bushings Triumph 6
D MK2 upper radiator hose question Jaguar 3
K loctie upper rod bushings Triumph 4
memphis Door Panel - Upper Piece? Austin Healey 8
