eejay56
I got a new front stub axle and Bentley says to press it in. I took it to the machine shop and with less than 1 ton of pressure the tip squished where the holes for the cotter pin are. Is there a special trick? Was the axle defective? How far should it go in? Does it really need to be pressed?
