MGB Rear Sway Bar
stevebn2bj7
Just starting the rebuild of a 74 GT and was wondering if there is any advantage to adding a rear sway bar from a later car. Appreciate your thoughts.
Hey Steve! I have a '72 GT, and I upgraded my front swaybar and added a rear (I don't recall the exact diameter of either). BUT: best (auto) decision I ever made. I love the way my car handles - balanced, flat, and responsive. Steering input is a bit higher than previous, but I'm running the stock steering wheel; and it's pretty big, so no problem. Every time I drive it, I love that car a little more.
Also upgraded the front brakes (drilled/slotted and V8 "green stuff" pads) and ensured the rears are perfect; added driving lights and put all headlights on relays. Now I just need to get the rust taken care of. (And then it's limited slip, traction bars, and supercharger). Then, I'm done. Maybe. :smile-new:
Phil
Only add a rear bar in conjunction with a heavier front bar.
jfarris For Sale TR 2-4 16MM (5/8”) Rear Sway Bar Triumph Classifieds 0
PatGalvin TR2/3/3A Rear Sway Bar experience Triumph 5
Jim_Gruber Rear Sway Bar - Needed? Spridgets 10
M TR4/4A TR4 rear sway bar installation Triumph 15
W Spitfire Rear Suspension Sway Bar?? on 1980 Spitfire Triumph 5
M Tips for replacing Rear Sway Bar Bushings? MG 0
K TR2/3/3A Panhard or Rear Sway Bar on aTR3? Triumph 10
T TR6 TR6 rear sway bar question Triumph 6
T TR6 Is this a TR6 rear sway bar? Triumph 10
tinman58 TR2/3/3A Rear TR3 sway bar Triumph 5
heliguy TR5/TR250 Rear sway bar install, TR250 Triumph 1
D Lowering a RB: Keep or discard rear sway bar? MG 7
vping Rear Spring Swap & Sway bar MG 37
C TR6 TR6 Rear Sway Bar Install ?? Triumph 17
martx-5 TR2/3/3A TR3 Rear Sway Bar Triumph 12
B Spitfire Spitfire Mk1 Rear Anti Roll Bar / Sway Bar Triumph 3
rovernut MGB-GT MGBGT Rear Sway Bar installation MG 4
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
Got_All_4 Matching front and rear Anti sway bars Triumph 2
Nunyas '77 and up rear sway bars. MG 4
Nunyas Rear Anti-sway/Anti-roll bars... MG 6
T TR2/3/3A Rear Wheel Bearing instillation on TR3 Triumph 7
mctriumph For Sale Tr6 rear bumper assembly/with over ride bar Triumph Classifieds 0
L For Sale JAGUAR E – TYPE: IRS REAR AXLE (EARLY), 2,88:1: Jaguar Classifieds 0
L For Sale AUSTIN HEALEY: REAR AXLE Austin Healey Classifieds 0
L For Sale AUSTIN HEALEY: REAR AXEL WITH DISC BREAKS Austin Healey Classifieds 0
Y MGB Possible rear axle issue? MG 0
71TR6 TR2/3/3A TR3 rear axle shims Triumph 7
B MGB Brakes scrapping sound from rear brakes on hard left or right turn. New wheel cyl, drums shoes ? MG 2
B Is the rear edge of the Bugeye bonnet sheet metal supposed to be bent inward? Spridgets 2
71TR6 TR2/3/3A TR3A rear shelf carpet Triumph 6
DornTRoriginal Wanted TR3B Left rear fender Triumph Classifieds 7
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
