I don't mind learning from mistakes, and it seems my latest was greasing up the rear axles of my solid axel TR4A after installing new oil seals in the axle tubes. The grease is spinning out and fouled my rear brakes. I've cleaned up the mess and replaced the brake shoes but time will tell whether I need to pull the axles and get the grease out. I'd think it would settle and stabilize after a few hundred miles. Was I only to grease the splines and leave it at that?
