MGA Question for the MGA coupe owners - will I fit?
Alfred E. Neuman
Hi all,
I'm new to the forum, but not to LBCs. Been a TR guy mostly, with my last being a 58 TR3A that received a frame-off restoration and was sold when we moved cross country. Finally in a position to get back at it and I'm looking at options.
I'd like a car that's a bit more usable for traveling than the roadsters were, so strongly considering coupes. I've followed Barney's MGA site for quite a while and the A seems like a fairly nice compromise in getting classic 50's styling in a *somewhat* reliable little coupe.
Main question I have is will I fit. I'm 6'-1" and on the lean side at under 175 pounds. I've only sat in a couple of A roadsters, and don't remember having too much trouble. Not sure if the coupe have the same seat travel or not. If you're on the taller side with a coupe, have you done anything to make it easier, like smaller diameter wheel, etc? There's not a ton of coupes around to try out and I don't want to travel looking if it's a no-go from the start.
I'm wanting a car to enjoy as-is for a while and then slowly upgrade to make more usable on the longer tours (North GA mountains, Blue Ridge Parkway type of stuff).
AEN
Here are a bunch of MGA's on E-Bay. I don't think you are two tall for one.
Bill M is presently putting together an MGA and could probably tell you alot.
You'll be ok but it will be a contortion to fit in. I had a Coupe a few years ago but sold it since I'm quite a bit heavier than you but the same height. It was too hard to get in and out. You should have enough headroom if the seats aren't over padded.
Thanks. I think I'll get with the local MG club here and see if anyone has a coupe they'd be willing to let me get in and see how comfortable it is. Seems like the performance is up to the task of back road touring without any strain. I steer clear of interstates in an LBC whenever possible (although the TR3A did make a run or two from Macon to Savannah well north of 80mph average on I-16:congratulatory:smile:
Good plan -- I've found LBC folks to be very willing to help a fellow car person out with a test drive.
As an aside, I'm 6'1" and 220# and I fit in a roadster fine from a body size perspective, but my really wide feet were not going to work. That said I fit in a Bugeye just fine so it's definitely worth getting into one.
One of the members of our local MG club has a coupe for sale through consignment and I went to take a good look at the car and see how it fit. I don't think there'll be any issues with fitting into a coupe so long as the seat rails are working correctly. My wife couldn't even reach the pedals with the seat back for me. The only think I might do is get an inch smaller steering wheel.
I'd say there's nearly as much room as in a TR.
Now I just have to find the right car. If anyone knows of a Dove Grey 1500 or 1600 Mk1 coupe for sale in excellent condition, I'd like to know about it.
Alfred
Excellent to hear that you fit! I remember that feeling when I first drove a Bugeye and discovered that I fit.
Good luck on the hunt. Your car is out there, be patient and you'll find it. :thumbsup:
I've had both, though I'm a bit shorter than you. The roadsters are more valuable to collectors, and if you look, you can find removable hard-tops. But you would still not have roll-up windows un;less you buy a coupe'. I'm in Texas, and I can tell you from experience that in Georgia, unless you only drive it between November and March, you will sweat off another 25 pounds. MGAs didn't have A/C!
Marvin Gruber MGA MGA wire wheel swap question. MG 5
PAUL161 MGA MGA Generator Question. MG 11
M MGA First MGA Question: Lubricants MG 2
T MGA MGA question - desperate MG 29
T MGA MGA overdrive - that is the question MG 23
M MGA Question... SAAB Shelby Wheel nuts for MGA MG 3
B MGA Starter question MGA/MGB MG 11
T MGA MGA Seat Question - frame bolt assembly pictures MG 4
Daimlerdb18 MGA Holy Blisters! MGA Paint Question MG 22
J MGA MGA - general question on buying one MG 8
T MGA MGA question - floorboard and firewall question MG 12
P MGA Early MGA MK2 question. MG 5
Daimlerdb18 MGA MGA master cylinder question MG 9
Banjo MGA another MGA MKII piston question MG 2
J MGA MGA Floor board screws- Question MG 3
SherpaPilot TR6 New Ammeter Install Question Triumph 5
R MGB 74 MGB Chrome bumper Grounding (Polarity) Question MG 7
D TR2/3/3A Question about bushing on the upper suspension.... Triumph 13
T TR2/3/3A Question regarding carpet installation Triumph 5
K TR2/3/3A One more coolant leak cylinder head question..... Triumph 5
Ohiobugeye cOIL qUESTION Spridgets 5
M MGB Disributor clamp question MG 2
K TR2/3/3A Cylinder head stud height question? Triumph 4
R TR6 Speedo Experts: Troubleshoot question… Triumph 10
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
jehuie HS2 carburetor question… now with video! British Motor Corp 20
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
