Quarter Eliptic spring bushing
Joe Schlosser
Is there any trick to replacing the bushing on a BR rear spring?? The spring is out for other reasons and as the bushing is 60 years old I thought I would replace.
It appears to be just a push in push out.
Are there any issues any one has come across?
I do not remember having any issues. Seemed like a straight forward process.
A Press is helpful. But I was able to clean up and cut bushing with a hacksaw and then used a big vise to press in the new bushing. Radius Arm Rods are totally different as those bushings are brazed in. For those I simply replaced with new but kept the old Radius Arm Rods so next time around will go to Poly Bushings.
Radius arm bushings are not brazed in (they are rubber).
They only look braised in as the arm is tubular and the bushing housing is braised/welded into the arm.
Gentleman, I stand corrected. Mine were in such bad shape I could not tell how they were fit. Thanks.
Bushing went out and in with no problems. Used vise as a press.
Also shimmed the front of the spring to correct 60 years of spring sag. Car is now level.
B Windscreen Pillar/Quarter Light Relationship Austin Healey 2
B Disassemble quarter eliptical leaf springs Spridgets 6
chicken BJ7 Rear Quarter Panels Austin Healey 6
J Tips for quarter elliiptic spring install Spridgets 3
M Quarter light rubber replacement Austin Healey 6
R Quarter light glass removal Austin Healey 6
T For BJ7/8 Safety: add a quarter light mirror [or two] Austin Healey 6
maxwedge5281 BN6 rear quarter panels installation Austin Healey 4
K TR2/3/3A Cockpit quarter rails? Triumph 11
R Rear quarter elliptical suspension changing Spridgets 12
bugedd Quarter Elliptical Springs Spridgets 6
B BJ7 & BJ8 Interior Rear Quarter Panels Austin Healey 12
CessnaTPA Rear Quarter Panels Austin Healey 14
PatGalvin TR2/3/3A PS Quarter Panel Repair - need a patch panel? Triumph 6
R Removing rear quarter elliptical Spridgets 5
drooartz Bugeye quarter panel structure Spridgets 5
B BJ7 Rear quarter panels Austin Healey 0
PatGalvin TR2/3/3A TR3 PS Quarter Panel Dog Leg needs a good home Triumph 2
Mickey Richaud T-Series GT Rear Quarter Window Catches MG 4
T Quarter light removal Austin Healey 5
chicken Quarter light position to high Austin Healey 2
T BE Quarter Elliptic Mounting Bolts - threads gone Spridgets 5
P GT6 GT6 Repairing Rust in Rear Quarter Triumph 8
HAN8L1965 Windshield Quarter light alignment? Spridgets 1
T Question regards Quarter Elliptic Rear Springs Spridgets 6
chicken How do the rear trim quarter panels fit Austin Healey 25
germanmichel How I can dismount the rear quarter panels ....? Austin Healey 4
davidk Quarter Master Throw out Bearing Triumph 8
v8mgbal quarter light mirror Spridgets 2
Stewart Windshield alignment quarter light issue MG 9
H door and rear quarter panels BN 7 Austin Healey 1
G TR2/3/3A QUARTER PANEL, L/H [dogleg] for TR3 Triumph 1
B Need BJ-7 Rear Interior Quarter Panels Austin Healey 2
G Quarter Light Frames Cracked! MG 0
G Quarter Light Frames MG 3
G Looking for Quarter Light assembly MG 4
AUSMHLY Attaching the quarter panel Austin Healey 6
AUSMHLY Attaching the quarter panels Austin Healey 8
RobSelina Rear quarter pannel replacement/conversion Spridgets 4
AUSMHLY Attaching the quarter panels Austin Healey 1
M bugeye quarter panel question Austin Healey 0
M bugeye quarter panel question Spridgets 2
6 rear semi eliptic spring plate - old school mechanic Spridgets 1
RobSelina WTB - 1/2 eliptic rear springs, stock or lowered. Spridgets 4
J Spitfire Choke Return Spring Triumph 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
SpeedyG TR4/4A Door window regulator spring Triumph 5
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
