TR2/3/3A Pulling engine & trans on TR3B - hoist attach?
Bruce100
Doing a frame off restoration. I'm getting ready to send my chassis and tub to get inner sills replaced, rear apron and some other pieces fixed. Body shop prefers engine/trans removed. Just finished assembling my HF 2 ton hoist and engine leveler. Tub is off, all is ready. Need to decide how to attach engine lever to engine and trans. The leveler is designed to use the head studs. I have heard folks say don't hoist from the head studs because of thread distortion/torque problems. There are two engine lift brackets. I could use those. What have you all done?
Bruce,
I used two screw end chain links on each end of of the levelers and then put them through the stock lifting points on the engine. Make sure that you get the links that are large enough for the weight of the engine (usually marked on the back of the package) but small enough to go through the ends of the leveler.
Here is the type of link that I am talking about. You can buy them at Home Depot etc.
Cheers,
M. Pied Lourd
Bruce100 said:
Pulled the engine and tyranny today
Was it <span style="font-style: italic">that</span> bad?
J Engine Pulling Austin Healey 6
AngliaGT MGB-GT '67 GT - Pulling Engine - Disconnect Driveshaft? MG 6
KVH TR4/4A Pulling Engine: Questions Triumph 6
steveg Newbie questions on pulling an engine Austin Healey 19
T TR4/4A Remind me on pulling an engine and transmission together or seperate Triumph 11
T TR4/4A How to determine if the crank is good before pulling the engine out Triumph 8
KVH TR4/4A Real Main Seal and Pulling the Engine Triumph 19
S Pulling the engine, clutch troubles? Spridgets 14
Rob Glasgow Pulling Engine Austin Healey 18
6 pulling engine Triumph 10
M Pulling the Engine Spridgets 12
hondo402000 TR6 TR6 Engine pulling process Triumph 20
hondo402000 TR6 Pulling TR6 Engine Triumph 31
Nelson Pulling the engine Spridgets 3
J Pulling the engine Triumph 18
T Engine pulling question - where connect Triumph 10
B Pulling Engine Austin Healey 4
B pulling engine but need help....pictures!! Spridgets 11
motofiaccone Engine pulling this week Spridgets 22
sim Pulling or lifting ? on engine and tranny 1958 Spridgets 16
vping T-Series Pulling the Engine & switching to OD MG 10
N Pulling Engine Triumph 11
JFS Wedge Pulling TR8 Engine Triumph 5
E TR6 Pulling the engine on the TR6 this weekend ... Triumph 3
Popeye What to check before pulling engine? Triumph 7
M Pulling XK engine Jaguar 8
roscoe Not Broken, But It Sure Hurts (Steering Wheel Pulling Accident) Austin Healey 5
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
Basil Wife's BMW Z4 - pulling my hair out! Other Cars 29
O Hesitation on pulling away from stop Jaguar 25
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
trotti Pulling off the rear wheel cylinder Austin Healey 11
TomChar TR6 Pulling the starter Triumph 2
C Pulling to left Spridgets 8
N Midget pulling??? Spridgets 14
A pulling to the left Triumph 8
T Wedge Pulling TR8 trans in the driveway? Triumph 12
Boink The use of HTML coding [and pulling in graphics] FORUM Navigation Questions 2
bugedd Pulling a datsun trans Spridgets 22
Darrell_Walker Pulling the plug.... Triumph 8
Tugboat TR2/3/3A TR3A Intermittent Pulling When Braking Triumph 5
T TR4/4A Tips on pulling the TR4a differential apart Triumph 2
B TR2/3/3A Pulling TR3 body off question Thanks Triumph 15
S MGB MGB pulling to rt. MG 6
J MGC MGC pulling Transmission MG 3
MadRiver MGC Pulling an MGC's head MG 8
T TR2/3/3A TR3A brakes pulling Triumph 7
T Tips on pulling a Bugeye 1098 & smooth case trans Spridgets 7
tweety pulling catalytic conv... better performance? Spridgets 3
D Spitfire Spitfire rear wheel pulling Triumph 6
