TR4/4A procedure for installing gauges etc
shoopal
Hi all
I've got the trans tunnel installed and I'm moving on to the next phase. Cables, carpets, yoke, plinth, electrical wiring (gauges, horn and OD relays, switches etc), wood dashboard.
Whats a good order to do these things so I don't get balled up and have to do stuff twice?
Advice cheerfully accepted
Al
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
S Fuel gauge calibration procedure Austin Healey 18
S Testing and Adjusting procedure for RB340 Austin Healey 4
J TR2/3/3A Inner sill replacement procedure ? Triumph 5
steveg Break In procedure Austin Healey 5
T TR4/4A Your procedure for checking out a new-used engine Triumph 6
S Procedure for setting and tuning HD8s? Austin Healey 10
S Procedure for cylinder head removal and re-installation - BJ8 Austin Healey 11
af3683 TR2/3/3A Correct Procedure to Raise TR3 Soft Top Triumph 7
R degreeing cam spec question and procedure Spridgets 23
Gliderman8 Is there a start-up procedure? ..... Triumph 10
M TR4/4A tr4A timing chain procedure? Triumph 9
R compression test procedure on 1500 midget Spridgets 5
Y BJ8 Clutch Master Cylinder Bleeding Procedure? Austin Healey 7
R Procedure to store engine Triumph 6
T Procedure to change points? Triumph 31
T Coil Test procedure ? Triumph 10
F GT6 GT6/TR6 Engine Painting Procedure... Triumph 3
J Engine Break In Procedure? Spridgets 12
T Engine bay painting procedure? Triumph 6
T Engine bay painting procedure? Triumph 0
D Torquing Procedure Racing 16
nevets oil filter change procedure Austin Healey 22
R_Lyle Replacing clutch / flywheel procedure Triumph 12
G Is there a procedure to remove the smog equipment? Spridgets 1
S Rebuilt Engine Breakin Procedure Austin Healey 4
nevets procedure for replacing brake fluid Austin Healey 14
Webb Sledge Engine Break In Procedure Triumph 9
Alfasudcrazy Starting procedure for 1975 Daimler 4.2 Jaguar 4
W What is the proper procedure for priming S.U.175's Triumph 4
S Proper Starting Procedure After Winter Storage Triumph 12
K TR2/3/3A Installing silicone valve cover gasket Triumph 6
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
KVH General Tech Reinstalling TR4A Interior Triumph 13
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
