KVH
I have two TR4As. Of late, and as some of you have noticed, I've been trying to get my "custom" one running as good as my standard road car. The custom one has a lightened flywheel, a special camshaft, Silverstones, a surrey top and an LSD Nissan differential. It's a cool car, but it just won't run like my other one.
After a few good rides with my new Pertronix (that so far I really like), I'm back to a puzzling symptom I'd been expecting might change. At around 3300 rpms I'm losing power in second and third gear. It's as if the engine is being choked off. I suspected bad timing, but that's not the issue, nor is it the fuel pump or carbs as best I can tell.
I don't know enough about mechanics to say whether I've got a compression or valve problem, but I can certainly do a compression test.
I do have another idea what might be going on here.
Could it be that my clutch is badly slipping? I've not heard of that being common with Triumphs and I do sense a loss of "power" at the higher rpms (in both second and third gear) which seems more consistent with something "engine" related. I know to some of you it should be obvious if my clutch is the problem, but I've just not experienced that before. And I'm not the one who added that lightened flywheel and new clutch 8 years ago.
One thing is clear: I could drive for hours and never notice any issue, especially in overdrive on the highway, if I weren't pressing for performance in the higher rpm ranges in second and third gear.
I'm actually feeling sluggishness in first gear as well, but not the noticeable "power choke" that I get in second and third gear at the higher rpm range. In other words, there's definitely an rpm component to my problem.
Maybe I should've run a compression test before posting this topic. There's a novel thought.
Anyway, my lack of expertise is evident so I'll await some good advice.
Thanks all.
Thanks all.
Hi Guest!
