So for the past couple of years I have been working on the mechanicals of a '59 Peerless which uses all Triumph running gear. According to the wiring diagram for it, it's a pos. ground set up just like the Triumphs are.
But today while in the trunk I noticed for the first time that the very old and very dead battery, which hides tucked in a rear fender, is wired as neg. ground. Now I have a problem. Does that mean that someone along the way converted it from pos. to a neg. ground or does it mean the last owner just put the battery in wrong?
Is there some way I can tell if it really has been changed to neg. ground? This car has not had an engine in it nor run for 20 years. What does changing over to neg. ground actually entail?
Any suggestions would be greatly appreciated!!!!!!!
John
John
