fmichaels
while i am feeling chatty, I am replacing the original leaf spring bushings with the red poly. On the old set up, there is a metal washer and a nylon washer on each side of the eyelet between the mounting bracket. it looks there is not enough room between the bracket and new bushing to put all these washers back. any thoughts?
Hi Guest!
