Is there a way to replace the Oil pump in a GT6 MKII with out having to pull the engine???
I have removed the motor mounts and lifted the engine as much I as I can, but still can't get enough clearance from the cross member to remove the sump (oil pan).
Any help or advice would be very welcome
Thanks
Mikey
Thanks
Mikey
Hi Guest!
