TRnorwegian
I have aired this noise problem previously under different headings, since suspecting it could be coming from specific sources. I'm now not really sure.
It started 50 miles back, when accellerating hard in 1st. gear. A scraping, whining metallic noise seemingly from somewhere near the transmission (but not grinding like marbles in a coffee jar). Lately it occurs in every gear whenever the drivetrain is under load.
It does not occur when shifting. Shifting is no problem, and also as long as I keep the clutch pedal to the bottom the noise is not present.
To make the noise appear only aquires pressing the throttle a tiny bit more when peddling along on a flat road, whatever gear I'm in. When I let off the accellerator the noise stops.
So far, it has been suggested to derive from:
The transmission, caused by defect thrust washer, lock plate or other internals.
The differentiental, caused by one or two teeth missing in the crown and pinion assembly.
The engine moving and rocking into radiator hoses or other parts, transmitting the noise further back.
I plan to drain the oil in the transmission on thursday, hoping this may supply further clues. I also have an british vintage expert take it for a spin, and harvest his reactions.
If the transmission is the culprit, has anyone published a tread describing some step by step repair? Which kit is recommendable when splitting the transmission? Other part I should exchange when the transmission is pulled out anyway?
Thanks, Anders
Thanks, Anders
Hi Guest!
