I'm a new Triumph (74 TR6) owner, looking for some advice on a problem. I'll try and be thorough with my explanation and with what I've done so far.
My dad was the previous owner of the car, and he drove it very rarely for the last 5 or so years. For the last few years, he said that whenever he'd go out for a short drive (<10 miles), it'd end up running rough, and sometimes even die. After letting it set for about 30 minutes, he'd start it back up and be able to make it back home.
When I got the car, I took it for a quick spin, and basically had the same issue. At first it ran great at any speed, any gear, any revs, any throttle. After 5 miles, it started to run rough, and eventually died. I'd try to start it, and it absolutely wouldn't fire. I saw it was getting spark, so figured it might be a fuel issue. Eventually, after numerous times trying to start it, it just fired right up. I drove it a few miles back home and it ran fine the whole way.
Since then, I've done a little work...
New Battery
Pertronix igntion (I was planning to do this conversion regardless of the issue). Timing was checked, and remained same
New coil (according to recommendation to match the new ignition system)
New Spark plugs (old plugs seemed to be fine...they didn't point to any obvious issues)
New fuel filter
New fuel pump
Disconnected vacuum retard on distributor
Checked carbs by opening air piston and gauging the reaction...both seemed to be good.
Tonight, I took it for another spin. It started up great, and ran great again for the first 5 miles. It might've even been running a tiny bit smoother than before, unless I just imagined that. After about 5 miles though, it started running rough again, like it was missing. It never died on me, like before, so I ended up making it home. From a stop, I could only get it to accelerate very slowly, with barely any throttle. While moving, it would run alright as long as I kept it around 2k RPM and didn't give it much throttle. As soon as I gave it more revs or throttle it would start missing. In neutral, it seemed to run fine anywhere, so the problem only came up while in gear.
Any suggestions on what I could check/try/replace next?
Thanks a lot for any help you can offer!
New Battery
New fuel filter
New fuel pump
Hi Guest!
