hondo402000
I have an A type over drive transmission going in when my engine gets back, I am in the process of replacing the front wiring harness and I am trying to figure out how to wire the OD, the challenge is in the wiring diagram for a 71 TR6, in the optional overdrive box in the corner of the diagram shows and says a N(brown wire) W(white wire) from fuse box. the question is where do they plug in to the fuse box. Would they plug in to the same locations of current White and Brown wires? I know they are both provide power to the OD circuit, the white looks like it engergises the relay coil and the brown wire pulls the solonoid in(which pulls more amps)
any help would be appreciate(Wayne)
Hondo
Hondo
