TR4nut
	Thought I'd start a separate thread on the overdrive issues I have, similar to tdskip.
In my case, I bought this spare gearbox from a guy and I helped him unload his storage unit - the gearbox was on end, with the od hanging up in the air. Who knows how long. Plenty of old gear oil in the case but I suspect most if not all drained out of the od.
When I put in fluid and tested, it was pretty much gummed up and wouldn't operate. Then it started working. Plenty of pressure, 380-400 psi. I don't see erratic pressure behavior so I don't think it is overshimmed.
I think perhaps there is some goo on the brake ring or clutch keeping things stuck, it could also be weak springs but at the moment I'm hoping not. Could also be very old oil in the operating pistons that is slowly coming out.
I hadn't thought of ATF but I like the idea, thanks I'm going to give it a try. I can run everything with the driveshaft detached so I'm not straining the system much.
				 Hi Guest!
Hi Guest!
 but were afraid to ask:
but were afraid to ask:  STOP!! Never post your email address in open forums. Bots can "harvest" your email! If you must share your email use a Private Message or use the
STOP!! Never post your email address in open forums. Bots can "harvest" your email! If you must share your email use a Private Message or use the  smilie in place of the real @
