How critical, really is the placement of the battery in an MGB. I ask because a former owner converted my MGB to a single battery on the right side of the car. On my car, of course, this is the driver's side (car is right hand drive). I just swapped in a new Miata battery (much lighter and smaller) and was wondering if it really mattered if driver and battery were on the same side.
Two questions:
1. Should I swap the battery to the passenger (left) side?
2. For folks who've done the single battery change, what do you use for a battery hold-down?
I need to get new battery cables made anyways, as the new battery posts are in a different spot and the current cable doesn't quite fit. Now would be the time to swap it to the other side.
I've picked up another of the little plastic battery boxes as well, so I can use the non-battery side for tools/oil/etc.
Two questions:
