I am about ready to install my new Mad Max seal and was curious about the sealer suggested in the instructions. I will try and get it scanned, but anyway here goes:
1) Remove the sump from the engine and take out the crankshaft. Remove both halves of the original oil catcher housing.
2) Screw one of the new housings loosely to the engine block. Remove the rear bearing shell of the crankshaft and place the centering tool in the bearing position.
3) Screw the other new housing loosely to the bearing cap and bolt it to the block. The centering tool remains in its position thus assuring the correct position of both new housings.
I am ok with the first 3 out of 5 instructions
4) Smear the sealing compound to the contact surfaces of both housings and tighten the eight screws. Ensure that the centering tool is still correctly positioned. Remove the bearing cap and new housing from the engine. Remove the centering tool.
My question is do they want sealant on the back side of the new housing or where the two ends meet? Again I am just trying to understand not be a critic. The next sentence says remove the bearing cap and new housing from the engine. Ok but if I just put sealant on the ends why remove them now. Why not wait with the sealant. Plus the instructions do not say to remove the oil catcher/new housings and put sealer on the back, but it does say to put sealer on “contact surfaces” am I supposed to put sealer on the back while they are in place and loose? Plus they say to use the “the sealer’” as if some sealer came with the kit.
5) Grease the oil seal generously. Fit the oil seal to the crankshaft, taking care not to damage or overstretch the spring. Position the oil seal so that the joint/split faces upwards.
Insert the crankshaft with the oil seal into the engine. Make sure use of sufficient sealing compound on all contact surfaces when inserting the bearing cap.
To my way of thinking it would not hurt to have sealant on the back of the oil catch/new housing, but I would have to put that on earlier before I tighten the screws. I guess between steps 3 and 4 I should remover the oil catchers/new housing and put some slow drying sealant like that red goop or maybe this aviation permatex I hear about. Again, I am not the sharpest tool in the shed and I am probably missing the obvious that a machinist would not, but I just want to do it correctly.
Hi Guest!
