Scotsman
	I have been told that the TR6 Steering lower Universal Joint (Moss 667-295) can be used to replace the lower Flex Joint (Moss 667-385) used on the TR4A. The advantage being that it removes some of the vagueness in the steering.
- Is this correct and are there any negatives to doing this?
- Is it a straight switch out or are there any other parts necessary
Please note, I am also replacing the original rack and pinion mounts which use rubber bushings with the Moss upgraded security mounting kit 667-293 in part to also improve the steering.
Thanks,
Richard
Thanks,
Richard
				 Hi Guest!
Hi Guest!
 but were afraid to ask:
but were afraid to ask:  STOP!! Never post your email address in open forums. Bots can "harvest" your email! If you must share your email use a Private Message or use the
STOP!! Never post your email address in open forums. Bots can "harvest" your email! If you must share your email use a Private Message or use the  smilie in place of the real @
