Assembly of the BN4 is coming along well, with a list of odds and ends left to do. Installing a new folding top is on that list.
I have a Longbridge top frame that appears more or less complete, except that it is missing the L shaped piece that is attached to one of the main top bows and extends below the left side pivot point and fits into the rubber block when the top is erected. I have the rubber block and the metal piece that the rubber block fits into. But the piece that fits into it is missing. I hope that explanation is clear enough; Longbridge owners likely will know what I'm talking about.
Does anyone out there have a Longbridge top with the missing piece still intact? If so, a few pictures - ideally with measurements of the piece would help immensely. Knowing the correct dimensions should make it possible to fabricate and weld the missing piece into place.
