KVH
Do many of you guys jack up the rear of the car by putting a jack under the differential? If so, are you careful to go forward of the diff pan to avoid stress on the pan and seal?
Also, I’m just curious – – are there any issues with stability or balancing by raising the vehicle from such a narrow “sole” point. I’ve just never done it that way.
I hesitate to admit it, but I use 2 low profile hydraulic jacks and walk back-and-forth from each side to raise the rear:
Hi Guest!
