Inside wipers?
Gundy
We got caught in a downpour this evening whilst taking
the BE for an errand run.
Not too bad as long as we maintained 60mph.
We both laughed when I turned on the wipers. They work
ok on the outside but had no effect on the inside which was
covered in raindrops. Now I remember the reason I always kept
a towel in the old Sprite. We just turned the useless things
off. A towel goes in the BE tomorrow as standard equipment.
Sprites...it's always an adventure.
I can raise the top on my Miata in about six seconds from the driver's seat! :jester:
I'm ducking the slings and arrows...
I'm not sure rain-x would have enough wind to work on the inside.
I keep one of those synthetic chamois things in my car.
I used to keep a roll of paper towels in the Sprite just for that reason but on one trip the car got so wet, the roll of paper towels were soaked.
So now I keep a spare wiper blade under the seat and use it to clear the inside rain.
Like you said "Inside wipers" :wink:
You Guys are are just seating to low in the seat sit up and drive like a MAN! :cooler:
Moss has the correct Gooogles if needed.......... :laugh:
I'm going with a Sham Wow...
As far as sitting up like a man....
That's what I had to do. My head is higher than the windshield
to start with so I just had to slightly lift my butt in the seat to see OVER the windshield. My Cool Daddy Ray Bans
are a wrap around style so no goggles needed. :jester:
My Austin Healey cap got SOAKED!
I have a set of Sham Wows.... the only purpose they seem to serve me is a expensive shop wrag... I was very disappointed when I got them and my meijer shamy dried my car better.
And Art.... you must have rotator cuffs of steel to be able to raise the miata top while in the drivers seat... I was able to do it ONCE in a emergency situation
I dunno about the Sham Wow, but the synthetic chamois I have is great for drying things. It does not leave a streak free dry like my natural chamois, but it holds more water and is easier to dry. But I primarily use it to stop water ingress and dry off the inside of the car when water does get in.
I have a miniature "window squeegee" (about 4" wide)that came with a window-tint application kit that works great for the inside of the windscreen. Periodic swipes and all's well!!
Those Sham Wow things really do soak up the water well.
For the car drying I'm still old school. Real chamois.
I've now attached a couple of golf towels to the travel
bags I sling in the LBCs for travel. It's a sort of pear shaped shoulder bag in nylon. Great for basics like wet wipes, first
aide kit, wallet , glass case, CDs, flashlight,spare keys etc.
Golf towels have rings and snaps to attach to your bag so it's
easy to attach them to the strap. Great sweat rags. They's
purdy too. :wink:
Ya know, pharmaceutical companies used to give away all sorts of useful promotional junk (like golf towels). That all went out the window when people started assuming that free ink pens were raising the cost of prescription drugs. :crazy:
Rain-X (both sides of windshield) and a golf towel in my my street cars.
Rain-X on helmet faceshield for racing.
I use it on our mini-van too....I love the stuff.
It takes about 15 seconds to raise the top my NB Miata.......roll bar slows it down :wink:
Seems like it takes about 15 <span style="text-decoration: underline">minutes</span> in my "take-a-part" top on the MGB.
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
T TR2/3/3A rings inside bevel Triumph 2
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
luke44 TR2/3/3A TR3 inside the tires track dimension Triumph 5
tr6nitjulius Oil flow view inside operating engine Other Cars 4
D What's inside the gas tank?? Spridgets 13
C Inside Door Handle Austin Healey 5
J Flaking Paint Inside Differential Austin Healey 6
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
FlyingCat Spitfire Inside door handle Triumph 2
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
L 100 ID plate inside cockpit Austin Healey 10
G TR4/4A Inside Windscreen Capping Triumph 6
T Frame: Inside Treatment? Austin Healey 8
S TR2/3/3A painting the body tub “inside” Triumph 31
DornTRoriginal TR2/3/3A Water Inside the Engine Triumph 11
DornTRoriginal TR2/3/3A Water Inside the Engine Triumph 4
RickB MGB Rain water getting inside behind dash MG 17
J BJ8 Inside Top Door Rails-How Attach? Austin Healey 6
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
max71 MGB Here's what the inside of a MGB mechanical gauge looks like MG 0
M BT7 Inside Threshold Plates Austin Healey 1
B Replacement of Small Black Wire inside Distributor Austin Healey 15
Jim_Gruber Painting inside a BE Boot Spridgets 8
Simmo MGB Have you ever tried removing the spring clip on the Keylock from inside the door MG 0
J Outside door handle opens but not inside Austin Healey 2
BoyRacer thermal barrier on inside of firewall Austin Healey 6
D Inside the frame rails Austin Healey 14
A TR2/3/3A TR-3A post 60K inside trunk latch photo Triumph 4
K Rough patch inside bore of SU? Triumph 2
P Odometer Finger Prints inside glass Triumph 9
T TR2/3/3A Peak inside the TR3 sill Triumph 8
R fuel tank cap., anything inside displacing volume? Spridgets 3
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
H inside of wings question Austin Healey 7
arizonamike TR5/TR250 TR250 Inside Rear View Mirror Mount. Triumph 2
wangdango inside of body panels? Austin Healey 10
TraceZ Our sprite is ALIVE - video inside!! Spridgets 7
M Help - inside my distributor Austin Healey 5
H filters inside of BJ air cleaner? Austin Healey 24
AUSMHLY Inside the car Blind Spot Mirror - MacGyvers back! Austin Healey 61
K TR4/4A Exterior of TR4 gas tank...inside OK Triumph 3
I Source for ribbed material for inside bugeye door? Spridgets 5
M Spitfire RARE BL Spitfire parts catalog see inside Triumph 0
T TR2/3/3A TR3 inside door linkage Triumph 8
eschneider help - points / contacts inside wiper motor ?????? Triumph 9
aeronca65t inside pass Spridgets 9
