charleyf
While rebuilding a set of HS6 carbs I discovered that the air hole in the lid of the float chamber has been plugged. I am assuming that that air hole needs to be open to allow the proper function of the float and fuel system. In the past I have had one needle valve stick open and allowed fuel to squirt out that opening. So I can imagine a previous owner not wanting that hole left open. But logic says to me that it needs to be there and open to prevent any pressure or vacuum to build up.
Am I correct?
Charley
Am I correct?
Charley
