Hi Guest! If you enjoy and benefit from your participation at British Car Forum, please consider supporting our efforts with a subscription. There are some perks with a member upgrade!
Oh, wait. Is it supposed to be like that? I just checked the TRF assembly manual and it is actually listed like that for early differentials. This was was removed from a 1974, but it's been off before judging by the differential mount repair. It looks like that is correct for the later units as well.
Hmmm...I would have thought there would be more of a plug type assembly.
My understanding was always that the cotter pin would be allowed to "jiggle" somewhat and keep the vent open. Of course, that doesn't necessarily happen in real life, at least not once things get a bit gunked up!
Pressure wash. Well as long as you remember there's a hole there. Maybe a temporary plug (chewing gum ?) around the cotter pin.
Then again, how much water can get in there ? You're going to drain and replace the oil anyway.
"how do you like my custom diff breather"
IMHO
I don't. sorry. But then i don't like any that come on any car.
I think there should be a 3/8" to 1/2" hose that runs across and up into the trunk space up high with a small filter on the end. That way you never get dirt or water into your diff.
Rob
