G
It has been a while. Now that the engine/tranny are on the garage floor, how do I pull the drive shaft forward to separate the splines to regrease them? There is a small collar behind the front u-joint that seems to want to turn. What is this collar. Believe it or not, this is not covered in the Bentley.
I remember adding some good grease to the splines several years ago, just forgot how.
Next, I need to put some extra-extra long grease fittings in all my rear u-joints temporarily to get some grease in them. Will remove the long ones and put the small ones back on, or even just a plug. Greasing these joints is quite a trick.
Hi Guest!
