hold metal together?
Hi all I have perhaps an obviously answerable question. If I am out working in the barn on my engine and the temperature is only 23 degrees, should I concern myself about loosening bolts at that frozen temperature or not. Does the cold steel hold the bolt tighter? Clearly rust and crud will hold metal together, but does a slightly sub-freezing temperature make a difference?
Steve
Steve
