TR6 help with TR6 windshield wiper arm removal
ichthos
It has been a while, and I have forgotten how to remove one of the windshield wiper arms. Can someone refresher on how to do this?
Thanks for your help.
Kevin
Big flat screw driver and a good cloth under it.Just pop it up.
You have to put the wiper arm in service position first. Otherwise... :wall:
tr6web TR6 TR6 Manifold gasket help Triumph 1
D TR6 Help with tr6 engine diagnosis Triumph 11
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
2wrench TR6 Help with points and condenser on '74 TR6 -- or better, choices to get rid of 'em. Triumph 25
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
L TR6 need help on long dead TR6 Triumph 16
7 TR6 help with tr6 hardtop value Triumph 5
M TR6 1975 TR6 Backfire from Carbs, running Lean - Help! Triumph 9
S TR6 Help! Need help from TR experts with this frustrating TR6 pushrod/rocker/valve issue Triumph 23
S TR6 Quick TR6 gear reduction starter wiring help Triumph 10
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
I TR6 69 TR6 courtesy liight wiring help please Triumph 5
B TR6 Help me choose new wheels for72 TR6 Triumph 7
I TR6 Distributor help on TR6 Triumph 5
I TR6 TR6 fender removal help please Triumph 10
I TR6 TR6 grill emplem help please. Triumph 16
2wrench TR6 Need help with '74 TR6 speedometer. Triumph 12
bash TR6 TR6 electrical help Triumph 11
I TR6 TR6 performance help Triumph 10
I TR6 TR6 window weatherstripping help please Triumph 1
I TR6 TR6 windscreen rubber seal help Triumph 2
I TR6 Help! melted wire in my TR6 Triumph 23
I TR6 TR6 courtesy light wiring help Triumph 26
I TR6 TR6 fuzzy seal clip help please Triumph 16
B TR6 Help with removal of TR6 crankshaft end bolt! Triumph 11
I TR6 Help installing TR6 door pulls and fuzzy seals Triumph 14
I TR6 Need help on 69 TR6 glove box info Triumph 0
I TR6 TR6 heater removal help please. Triumph 5
hondo402000 TR6 Electric Fan help needed for TR6 Triumph 5
I TR6 TR6 kidney pad installation help please Triumph 7
I TR6 Help with 69 TR6 parts, part 2 Triumph 14
I TR6 Help with TR6 parts please Triumph 3
O TR6 1971 TR6 Starter Help Triumph 1
I TR6 TR6 bonnet help Triumph 7
T TR6 TR6 pricing help Triumph 16
G TR6 TR6 Help needed Triumph 13
I TR6 TR6 luggage rack - repair help Triumph 13
I TR6 TR6 PDWA switch help please Triumph 10
I TR6 TR6 horn help please Triumph 13
I TR6 TR6 horn help please Triumph 2
hondo402000 TR6 Need Help on 71 TR6 Overdrive Wiring Triumph 9
I TR6 Help with rebuilding TR6 heater system please Triumph 19
I TR6 Carb help please for 69 TR6 Triumph 14
I TR6 TR6 gas line leak - please help Triumph 15
I TR6 TR6 oil sending unit thread size help please? Triumph 12
I TR6 TR6 accelerator bar busing replacement help please Triumph 10
S TR6 TR6 Springs__HELP Triumph 11
V TR6 Help w/ toe dolly TR6 Triumph 14
hondo402000 TR6 TR6 reverse light switch wiring help Triumph 4
