heat shield
6773
will a heat shield off su hs4 carbs on mg fit on the 1500 midget uk su hs4. i am changing my 1975 midget 1500 over to dual su hs4 and do not have heat shield
Jack, hate to say this but you aremost likely BEST off just making one your self from scratch! :crazyeyes:
:cheers:
Ed
I bought one from ashley hinton, cant seem to find a link for it now. Very nice piece fit was beautiful.
What needles do you plan to use?
mark
I think stainless steel would be nice.
V heat shield Triumph Classifieds 7
AH67 Heat Shield finish 66 Type Jaguar 5
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
K TR2/3/3A Revington alternator heat shield. Triumph 0
K TR2/3/3A DIY Alternator heat shield>>> Triumph 2
L 100/ Moss Heat Shield Austin Healey 2
DornTRoriginal TR2/3/3A Heat Shield Issues Triumph 6
GTP1960 TR2/3/3A Carb. Heat shield location? Triumph 11
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
T TR2/3/3A Fuel line heat shield Triumph 39
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
J Side exhaust heat shield Austin Healey 23
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Heat shield for tranny cover Triumph 4
R Heat Shield Detail Austin Healey 3
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
tahoe healey Dynamat heat shield Austin Healey 8
KVH Carb Heat Shield Installation Triumph 2
D Carb Heat Shield Spridgets 12
HealeyDave Intake manifold heat shield fitting issue Austin Healey 2
R TR4/4A Tr4a, alternator heat shield Triumph 9
G HEAT SHIELD! Austin Healey 10
R No Heat Shield Cause Dieseling? MG 1
I How do I install Bugeye heat shield? Spridgets 4
Gliderman8 Heat Shield - will it solve my problem.... Triumph 15
I Bugeye heat shield color? Spridgets 11
Dudly Heat shield Triumph 0
19_again Carb heat shield MG 7
bigjones Vapor lock. Heat shield for fuel pump? Spridgets 5
M SU Carb Heat Shield Triumph 6
c5racer Gaskets with the heat shield? Spridgets 0
T Heat shield pictures- anyone have one handy? Triumph 3
J Heat Shield Material / Carpet Dye? Austin Healey 15
Brosky Goodparts Triple Carb Heat Shield Triumph 16
Brosky Triple ZS Owners - new Heat Shield from Goodparts Triumph 7
19_again MGB MGB exhaust heat shield MG 3
Trick6 Tri Stromberg Heat Shield Coming This Spring/Summe Triumph 16
LastDeadLast Heat shield for HS8 carbs Triumph 3
tony barnhill MG Midget Heat Shield Spridgets 30
newmexTR3 TR2/3/3A TR3 Carburettor Heat Shield install Triumph 4
Steve P. '78 Midget carb heat shield? Spridgets 1
T Ratco Cable + Heat shield Triumph 30
mjobrien Cockpit Floor Heat Shield Austin Healey 4
kyreb1862 MGB Heat Shield Color On A 77 MGB MG 1
Musicman Heat Shield Triumph 8
A SU H1 heat shield Spridgets 5
LastDeadLast Stainless Heat Shield for Triple Carb Manifold Triumph 7
R Exhaust Heat Shield Austin Healey 3
