TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3?
i believe the bellhousing is thicker so you need longer studs. not sure of other issues
You'll also need to slot the holes where the rear mount attaches to the cross member. The 4-synchro boxes are around 3/8" longer through the mounting points.
Depending on the vintage of TR6, you may need longer mounting bolts and some adjustments to the clutch slave mounting. I have a later TR6 box and had to shorten the clutch pushrod to make it fit with the slave in the original position.
The shorter input shaft does not seem to be a problem. Still, it wouldn't hurt to replace the pilot bearing while you're in there. Make sure the locating dowels are in place as well.
Don't forget to wire and test the switches before buttoning it up. In retrospect, I wish I had just replaced the one that acted a bit funny instead of just taking out the shim.
I asked the same question at a club breakfast this morning.
After removing the old tranny, replaced the top two bellhousing bolts with studs (bolts with the heads cut off). This way you can "hang" the new tranny on these until the remaining bolts are in place. I thought this was a clever tip.
I used a 1976 Triumph 2500TC Gerarbox and J type OD. Apart from the advice above I sent the flywheel to the clutch suppliers and they surface ground and re tapped it fot a new Diaphram clutch.
The TR3A now thinks it's twenty years younger.
I ment also to say that modified rear mount brackets are required. It is somewhat of a pain to manufacturte and in desperation I purchased a Moss bracket. It works like a charm
Randall,
I haven't heard about slave issues. Good to know. The OD plate number (1975) says its from a TR6 from April of 71. I think its one of the last series of A types.
Moss shows the same part number for the pilot bushing in the TR3 and TR6 so I think I should be good there. It does mention a flywheel bushing on the TR6 but not the TR3, but I'm not sure that would make a difference since I'm using the TR3 flywheel.
Thanks,
John
The late TR6 o/d has an entirely different rear trans mount. You can make it work but there are some mods to make, otherwise like the guys before me have mentioned.
Marv
Got_All_4 TR2/3/3A Has anyone installed one of these slack limiting plates Triumph 4
roofman Has anyone installed an electronic voltage ... Triumph 19
D TR6 Diamond Back tire striping, has anyone used them? Triumph 3
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
Got_All_4 TR2/3/3A Has anyone tried this new steering box top plate Triumph 14
steveg Has anyone used a knock sensor? Austin Healey 0
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
G TR4/4A Anyone know if this car has sold yet? Triumph 0
Sherlock Spokane Race Track, has anyone been there? Racing 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
G Has anyone here had any dealings with ANGLO PARTS.COM ? Austin Healey 4
MY66AH Has anyone used this paint?? Spridgets 7
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
H Has anyone changed their electrical distribution? Austin Healey 7
regularman Has anyone here put a bugeye front end on a square Spridgets 2
scoutll Exhaust manifold has cracked-Anyone have a spare? Spridgets 2
60TR3A Has Anyone Undercoated Their Car? Triumph 27
scoutll Has anyone had a hardtop shipped? Spridgets 15
S Has anyone ever seen or heard of this? Austin Healey 9
T Advice, has anyone done this Triumph 2
jlaird Has anyone noticed Spridgets 20
NardisCNC Has anyone used the Oberg Engine Tilt Lift?? Spridgets 15
Cookie Has anyone changed wheel cylinders? Spridgets 20
bgbassplyr Has anyone else Other British Cars 9
L Has anyone ever had to.... Spridgets 12
gubba Has anyone here used this Rack & Pinion? Triumph 8
M Side Curtain Rubber Has anyone tried MacGregor? Spridgets 2
T TR6 Has anyone ever made a new TR6? Triumph 20
angelfj1 Octane Boosters - Has Anyone Mixed their Own? Restoration & Tools 5
S Has anyone seen....... British Motor Corp 1
weewillie has anyone Restoration & Tools 12
angelfj1 Liquid Powder Coating - has anyone tried this? Restoration & Tools 4
regularman Has anyone ever done any wind tunnel tests.. Spridgets 22
G TR6 If anyone has had their TR6 on the dyno to tune Triumph 16
C Has anyone seen........ Triumph 6
healeyboz Has anyone.... Spridgets 5
MGBGT_noob MGB Has anyone ever tried this with an MGB? MG 10
jlaird Has anyone Spridgets 4
H Anyone Own or Has Driven a TVR Sagaris? TVR 11
mgblue79 Has anyone tried E85? Spridgets 16
AweMan Has anyone ever .............. Triumph 10
W Home-made tonneau - has anyone tried? Triumph 15
Nunyas has anyone else seen this? MG 14
J Has anyone converted to TBI? Triumph 11
neilh Has anyone successfully patched a leaking tank? Spridgets 15
1 Has anyone ever heard this tip? "Weeping" head MG 11
