Gerald_Gordon
Since new rubber door seals were installed in connection with a respray, closing the doors of my TR4 has required considerable force. Has any one else experienced this, and have you found a solution?
If the cross section were too thick, perhaps softening the rubber with a heat lamp and/or a heat gun and then closing the door until the rubber cooled might permanently compress the material. If the material were too stiff, though, then that technique might not work.
Your suggestions would be most welcome.
