TR2/3/3A Fuel pump for a Triumph TR3 or 4?
Jerry
Anybody know a part number that I could pick up at a parts house tomorrow for a TR4 or TR3? Mechanical pump? I want to get it started and don't want to wait for parts.
Or rebuild kit number?
Jerry
I carry a cheap electric pump as a get-me-home spare for the TRs. Works just fine, also use it to pump gas to drain the tank, etc.
My receipt from Autozone shows a SKU/part number of #191528 E8016S.
Googling E8016S will show you the pump.
But for 'just starting' you can fill the fuel bowls and run the engine. For a bit more run time you can rig a gravity fuel source or use a funnel in the fuel line to the carbs.
Whatever you do, have the fire extinguisher handy.
While I got it started, there is still a leak at the fuel pump and the bottom of the carbs. Also due to the loud noise produced, I decided to put some of the exhaust on and broke off a stud. So tomorrow is drill out the stud, fix a water leak and fix the gas leaks.
I still would like to rebuild the pump but I don't want to wait for an order to be shipped. Anyone have a part number for a parts house?
