I got all my TR6 project all buttoned up, the clutch hydraulics bled and decided to actually take it on its first shakedown on the road. First thing I noticed was that it was running very well despite having the head off, carbs off, etc... and it was shifting well -- and even the Overdrive was working like a champ. Speedo wasn't working, but given it came with a new cable, I figured it wouldn't work.
I decided to turn around about six blocks down the road and start heading back to my garage. About a block later...
...no engine power. It was firing a little, but just coughing.
When I went to neutral and revved it, it seemed to rev up. In gear under load it just crapped out. I was able to cough and sputter the rest of the way at about 10mph back to the garage. It would idle fine and rev in neutral. Managed to get it back into the garage under its own power after it stalled in the driveway.
My gut tells me something like a bad coil or condenser. (I replaced the condenser, but not the coil.) Seems to me that if it was fuel, it wouldn't make a difference if it was in gear or out of gear, right?
I did the typical ADD thing -- once in the garage, instead of troubleshooting, I decided to attack fixing the speedo cable and redoing the seats and carpet.
But if anyone has had this symptom happed to them in the past, I'm all ears about the source of the problem.
Thanks,
Sam
Thanks,
Sam
