Fiat Master Cylinder for Healey - angle question
steveg
I'm going to use this .75" Fiat tandem master cylinder for my revised dual braking system.
The mounting flange is at an angle compared to the Girling. My question is - if I mount it as shown in the picture with the flange holes verticall aligned, will there be a problem with the input ports being angled?
Would like an answer based on experience, if possible. Thanks in advance.
Steve:
I used the same or similar tandem master cylinder for a dual braking system conversion on my BT7 tri-carb. To get the lower brake pipe (from the lower middle outlet on your picture) to clear, I had to cut a small, rectangular piece out of the support that runs from the firewall to the back of the front wheel well. If you have access to back issues of CHATTER, Fred Crowley had an excellent article on the subject in the May, 1995 issue. If I remember correctly, I did this conversion within a year or two after that article. I have been quite satisfied with the conversion.
In retrospect, if I had to do the conversion again, I would see if I could rotate the master cylinder so that the inlet and outlet ports were pointing up, and drill a couple of bolt-sized holes in the firewall to bolt the master cylinder in that position. It might also be possible to fabricate a bracket that would allow the use of the master cylinder mounting flange and the existing mounting bolt holes that would have the ports pointing up, without drilling new bolt holes.
Jerry
FYI, I used the MC from a Nissan 1200 and didn't have this problem. The holes were vertical and lined up with the stock holes. The MC from a Nissan B210 also works the same way.
Steve:
Jerry
Checking the pedal box, if the Fiat MC is oriented with the ports exactly vertical, the bolt at the 4:30-o'clock position protrudes into the right-hand wall of the pedal box, as viewed from the pedal side.
I'm thinking about making an adapter out of 3/16" or 1/4" steel to allow the upright alignment, but was wondering if it would be possible to get by without it.
Does anyone have an extra pedal box to sell? I'd prefer to modify one off the car and do a quick swapout at install time.
They are plastic and are clamped to the MC. If you want a remote reservoir, you could try the Wilwood one that dougie uses: https://www.hrpworld.com/client_images/ecommerce/client_39/products/pdf_5232_1.pdf
Thanks John, I'm aware of the wilwood 1" tandem remote MC. If they made it in 3/4" would have gone with it.
Went with the Fiat because it's 3/4" & remote and my current 3/4" girling works perfectly with my Toyota 4-pot discs. Not only that, the Fiat is under $30 with free shipping on Amazon Prime.
Main problem with the Fiat is the connections are M10 x 1.25 bubble flare. 10 x 1.25 is obsolete and difficult but not impossible to get bubble adapters and tube nuts for. I have those sourced and on the way.
steveg Fiat Dual Master Cylinder Austin Healey 7
AngliaGT Fiat 600 + Others Spotted 0
P FIat 500 Other Cars 5
glemon Fiat 1200 Sports Car Spotted 3
anarchy99 Old fiat on the Amalfi coast Spotted 6
JPSmit 2017 Fiat 124 Spider Other Cars 5
coldplugs MGB's and a Fiat in Boothbay Harbor [Maine] Spotted 5
D 1 month review: 2012 Fiat 500 Other Cars 9
D Triumph meets Fiat [pics] Other Cars 5
DrEntropy Just learned FIAT is coming! Other Cars 28
aeronca65t FIAT-Mille Miglia Other Cars 5
JPSmit New Fiat Spotted 4
K Fiat Cinquecento Other Cars 7
58Custom Fiat engine height in Spridget Spridgets 7
D FIAT 124 Spider Spotted 0
bgbassplyr 1959 ABARTH 750 ALLEMANO FIAT SPYDER - 9,000 MILES Other Cars 4
jvandyke I bought a Fiat X1/9....I think Other Cars 33
K McLaren: Fiat/Mini Type Fuel Saver? Triumph 1
Sherlock For the Fiat collectors Other Cars 1
abarth69 Chrysler, Fiat discuss partnership Other Cars 7
vping Who posted about a Fiat 1500? Other Cars 5
aeronca65t Seinfeld's "FIAT" accident? Other Cars 21
coldplugs Fiat-Abarth on eBay Other Cars 20
eschneider anyone seen a spifire with a fiat twincam? Triumph 25
H Is a Fiat X1/9 acceptable in "other cars" group? Other Cars 19
SilentUnicorn Fiat mirrors. . ya Gotta e Kidding.......right? Other Cars 9
H My old Fiat 850 is back on Ebay Other Cars 2
bugimike Nice Fiat on ebay! Other Cars 3
eschneider how about a SUPERCHARGED Fiat 850 ????! Other Cars 4
H Fiat 850 spotted in a film Other Cars 0
beaulieu Hotrodding a Fiat 600 with Fiat 850 motor/ trans ? Other Cars 35
H Fiat 850 back on EBAY Other Cars 3
H Fiat 850 Slug now on EBAY Other Cars 15
H 73 Fiat Spider Latest Other Cars 18
Tullamore Fiat X1/9 Crushed on Mythbusters Other Cars 12
Tullamore 71 Fiat 850 Sport Spider Other Cars 5
DrEntropy Hunting a Fiat 2000 Spyder for a friend: Other Cars 0
H 73 Fiat Spider 850 Other Cars 19
Steve_S 115 MPH in a Fiat punto? Other Cars 4
6 Bench Bleeding a New Master Cylinder Spridgets 3
L Removing Master Cylinder Without Paint Damage Austin Healey 27
L TRW-Lucas Brand Master Cylinders Austin Healey 2
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
