laneriddle
Hi, my '66 Cooper S is running good,except that after driving awhile the idle is much faster than when it starts cold.The SU carbs are newly rebuilt.I removed the PCV valve and plugged the hole in the manifold,I think that helped ,but not sure yet.Any ideas? I sprayed WD40 around the ends of the throttle shafts while the car is idling and it almost stalled out,so I guess they are sucking air? Would that cause the idle to speed up after the car warms up?
