Chet Zerlin
Hi all,
After installing new door panels in my BN6 I'm finding that the doors don't close fully. Apparently the new panels are slightly thicker than the old ones and the hangup seems to be at the front lower edge. Since it prevents the front lower edge from closing fully that pushes the entire door out - and due to the angle it gets worse the further toward the rear.
Is there a recommended method of adjusting this? I noticed that my old door panels had developed indentations that I'm thinking helped everything align properly - do I simply keep the doors shut and hope similar indentations solve the issue? Is there a possibility of being able to "bend" the front bottom edge of the opening (in the car not the door) to allow a greater separation between the door panel and the area it presses against when closed?
Ideas and suggestions greatly appreciated!
Thanks!
Chet
Thanks!
Chet
