Hi All,
Au contrare!
TR4 Service Manual, pg 1.130 (Brooklands reprint):
[ QUOTE ]
Distributor Drive Gear End Float
Determine the requisite amount of packing under the distributor pedestal to give .003 to .007" distributor gear end float by the following procedure:
Insert the oil pump drive shaft through the bush and rotate the shaft to engage the driving tongue with the oil pump driving slot. Measure the thickness of a plain washer with an internal diameter of 1/2". Slide the washer and gear over the shaft and fit the distributor pedestal (note: no "packing" is fitted at this time).
Measure the gap between the distributor pedestal and the cylinder block as shown (with a feeler gauger). Subtract this dimension from the washer thickness to determine the end float of the gear.
Example 1
If the washer thickness is .062" and the width of the gap is .060", then the end float will be +.002". This is insufficient and requires a packing of .003" thickness to produce an end float of .005".
Example 2
Thickness of washer .062". Width of gap .065", gear interference is .003" (-.003" float). In this example, the interference of .003" requires packing of .008" thickness to give an end float of .005".
Remove the pedestal, gear and drive shaft and withdraw the 1/2" washer from the shaft.
[/ QUOTE ]
Sections covering the rest of the distributor/pedestal alignment and fitting follow, during which the pedestal is installed with the correct thickness of packing, as determined by the above procedure.
Maybe it's not super critical, I dunno, but it's pretty easy to check.
