guzzul
I have the differential out of my '78 Spitfire. It was whining at speed, so i thought the pinion/ring gears may be worn. As it turns out, one of the output shafts does have a growly bearing, so I'm thinking I need to replace that.
On checking the ring and pinion by just moving it back and forth, there doesn't seem to be too much 'wiggle', and they don't look overly worn (althoug I don't really know what I'm looking for here...). But the sun and planet gears do seem to have a fair amount of play in them, primarily the sun gears (i.e. the gears with the splined centers that the output shafts slide into).
In fact, I can move the sun gears laterally about 1/16"-1/8". I'm not sure how much of the lateral 'slop' is supposed to be there, or whether these gears and the planet gears are supposed to be pretty tight together. There is wear on the teeth, for sure, this is an old diff. But how much is too much? https://www.britishcarforum.com/ubbthreads/images/icons/confused.gif
Anybody have any thoughts?
