Moseso
I have a 3-wire Denso alternator set up on my TR3. A little odd behavior of the amp gauge got me thinking about gremlins, so I checked a few things.
When the ignition switch is off, there should be no load on the battery from <span style="font-style: italic">anywhere</span>. If you pull the ground cable off the battery and put a voltmeter between the battery and the cable, there should be no voltage reading -- open circuit -- no way for electrons to get from hither to yon. This is not the case on my car. I get a fine 13.26V reading. So I tried the ammeter to see how much is draining. Not much: 0.4 milliamps.
There is ONLY ONE unswitched wire in the whole dang car, and that is the large one that runs from the output terminal of the alternator to the ammeter, and from there to the battery positive terminal, via the solenoid. Sure enough, when I disconnect that wire, the mystery voltage disappears.
Enough description! The question is -- Is this normal behavior of the "solid state" internal voltage regulator on my alt, or is this an aberration requiring corrective action? Anybody here know?
(A total aside: This all serves me completely right for thinking I had banished the Lucas Electrical demons from my car through use of the Denso alt AND starter. The starter is stone dead after <50 starts, and now I am thinking the alt ain't working right either.)
