I have a 65 BJ8
I have read through the archives on this subject, but have a question on what really needs to be disconnected to jack the engine up and how much it really needs to jacked up.
The steps as I understand it are:
1) Remove radiator, fan, flatten the lock tab, and use PB blaster or equivalent to help loosen the nut.
2) Loosen the engine mount bolts, replace the two rear bolts with longer bolts to keep things aligned.
3) disconnect a) throttle linkage, b) exhaust pipes at manifold flange, and c) loosen the overdrive - chassis tie rod
4) jack the engine up and remove the nut with 1 11/16 impact wrench or slugging wrench, socket or spanner depending on the difficulty.
The questions I have is how much does the engine need to jacked up? ~ 3.5 inch to clear harmonic balancer or ~ 2.5 in to clear the pulley? Do I really have to disconnect all the items in # 3? Anything else I may have missed that need to be disconnected?
Trying to understand how cautious I need to be with disconnecting things / clearances, since I last did this 30 years ago on an engine stand.
Hopefully can get advice from someone who has done this with engine in the car.
Johnski
Johnski
